BarneyS's avatar
BarneyS
Explorer III
Mar 28, 2016
Linux Ubuntu problem
I run Ubuntu on one of my laptops. Recently, an "update" came through and when it was done, my laptop WiFi was gone. I have no signal indicator at the top and I cannot connect to my router any longer to get online. Now there is no way to fix the problem via an update or other download. Anybody have suggestions.
I have already tried to use Windows to download the latest version but it will not install, probably due to the older version already being installed. Also, I cannot find any way to uninstall Ubuntu. Anybody know how? Keep in mind that I am not an expert in either computers or especially Linux.
Thank you.
Barney
  • Not what you asked about, just want to throw this in. I tried ubuntu for a while and didn't like it a whole lot. Switched to mint cinnamon 17.3 and like it much better just because the GUI is pretty close to the windows gui. If you're not familiar with it, you will also want to get grub customizer (for either mint or ubuntu), which IMO should be a standard part of the system. You can burn a bootable DVD of mint and boot without installing it to try it out.
  • Didn't realize you were using a dual-boot environment? Which can sometimes cause problems with OS upgrades.
    As I mentioned, I'm not familiar with Ubuntu. However, I would check to make sure your specific WiFi adapter is enabled using Ifconfig? I believe Ubuntu should do this automatically? But still wondering if the upgrade disabled the specific network adapter?
    CentOS, which I'm more familiar and just basically a free version of Red Hat Linux Enterprise, does not enable network adapters by default. No wifi or ethernet. You have to manually enable the adapter(s), or else modify the specific script option to "onboot=on" to avoid having to do so upon startup each time.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
