Codeman671's avatar
Codeman671
Looking to add satellite
I have a 2008 Jayco 36FS bunkhouse and am looking to add satellite (Directv). I want an in-motion roof mount unit as we mainly will be using it on the road for the kids.
We currently have 4 tvs- 1 in the master, one in the hallway across from the bunkbeds, 1 in the cabover and another for outside use in a storage compartment. We would like to be able to put signal to all 4 jacks if possible. Can this be done? I do not need hd, standard def is fine as that is what we have at home (I do not have clear sight to the hd satellite at home). We currently have a ton of boxes on our plan, and if they work could put them in the rv for trips instead of buying more if this can be done.
I noticed that Wineguard states 2 receivers, KVH states multiple. I would think with multiswitches we should be able to get signal to all just like in our house.
What is the best setup to go with?
  • powderman426 wrote:
    You say you want an in motion unit. Surely you don't plan on having someone in the trailer while traveling? Did I miss something?
    I thought the same but maybe that model number bunkhouse is a Class C or A?
  • With a KD as we have. You can also run 2 receivers or a DVR.
  • You say you want an in motion unit. Surely you don't plan on having someone in the trailer while traveling? Did I miss something?
