dahkota
Jun 10, 2015Explorer
I use Easy Tether. In fact, I'm using it right now. It can also be found in the Amazon Store and Google Play. The lite version is free - you can use that to test it out.
You install SW on both your phone and computer. Once you have it up and running, you can just leave it on on your phone and reconnect with your computer. There is an issue with Samsung phones (I have one) where you need to download a special driver - you can find it on their website.
I've used Easy Tether for over two years with hardly any problems and usually the DL/UL speeds are better than wifi.
Edit to add: it uses USB or bluetooth to connect the computer to the phone.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
