NaioExplorer IIOct 09, 2018Mobley problemsMy Mobley has been acting strangely for about a month. I have to redo the connection to it on average about once per hour of use. But it varies a lot. I don't think that I have had the update, becau...Show More
garry1pExplorerOct 11, 2018I think the biggest reason for the shut down problem is the unit is designed to turn off if the voltage falls to 11.5VDC.There is no way to tell or sure unless you can test the power module under load.I'm not sure how you are powering the mobility but try another power source.
About RV Must HavesHave a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 05, 2026
Related ContentReplace MobleyOriginal Mobley Obsolete?MobleyAtwood water heater problemTroubleshoot fridge problem...
