All of the Mobley's are being updated to 1.0.3. It removes the "Never" timeout choice and also locks the SIM to the Mobley so it can't be used in another device. There are ways around both issues though. The Mobley will stay "alive" as long as the supply voltage stays high enough to simulate a running vehicle voltage, and the SIM lock problem can be fixed by asking AT&T tech support for a couple of PUK (Personal Unlocking Key) codes. The codes are 8-digits and are used when asked after entering an incorrect 4-digit unlock code 3 or 4 times. Only one code is needed, so save the second one as a spare. If you're not removing the SIM from the Mobley, just leave it locked for now, it'll work fine.
