- MrWizardModeratori found this on howardforums.com
don't know if it will help you, but it is worth checking
When I log in to my AT&T account (I only have the Mobley with them) and click on manage my device and features it says: "My current features:
You currently don't have any features on your account"
and it says this:
"See device options
Upgrade device See optionrightArrow
Suspend device See optionrightArrow
Unlock a device See optionrightArrow
Manage data See optionrightArrow
Update caller ID info See optionrightArrow
See accessories See optionrightArrow
Manage Sponsored Data"
i do not know if unlock device will unlock the SIM or have No effect on the SIM
if your SIM gets screwed you can goto ATT store and get a NEW sim assigned to your mobley
then stick in the unite - BluStemExplorerNow know that the update was more than a menu change.
- lryrob9301ExplorerThe new Mobley update has been reported to be locking the SIM so it can't be used in another device. AT&T's way of controlling unlimited plan usage.
- BluStemExplorer
magicbus wrote:
Did the Unite ever work or did you just buy it?
Yes it has worked no problem all summer. I do put it back in the Mobley for trips with the grandchildren.
The Unite now reports 3/5 attempts. That's just from booting it with the SIM installed. I never even entered a PIN.
Will excess attempts kill the SIM?? I don't want to find out.
I don't think I'll ask for any PIN from AT&T. My Unite is now a doorstop unless something good is discovered. - jcpainterExplorerReports now from other forums of the same issue.
- magicbusExplorer IIDid the Unite ever work or did you just buy it?
Dave - jcpainterExplorerWell, shucky dern! Please let us know if you have success getting a PUK that allows you to use the Mobley SIM in another device.
- BluStemExplorer
jcpainter wrote:
Does it work if you put it back into the Mobley?
Yes it works in the Mobley. I'm using it now. - jcpainterExplorer
BluStem wrote:
Went and moved my SIM from my Mobley to my Unite and get a message that the SIM is PIN locked. Had a notice to enter a PIN.
The end of SIM swapping?
I never had this before, it just worked.
Does it work if you put it back into the Mobley? - Ed_GeeExplorer II
You will need to obtain a PUK (Pin Unlock Key) from your carrier.....go to a local store.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 27, 2025
