TechWriter wrote:
georgelesley wrote:
One thing i did not mention before is that because the house dish uses the hybrid lnb and the rv dish uses the DPH42 switch I have to do a test switch when I move it back and forth so the hopper knows what setup to work with. Very easy to do, just push home button on remote, then diagnostics, then dish button on left of screen, then test switch button.
Instead of the "test switch" button (a soft reset), I recommend doing a Test Installation via the software Diagnostics tile . . .
. . . because you can make sure all sats are present and I think it's faster than by pressing test switch.
Finally, while the Winegard Travler + DPH42 switch works great, I recommend using the Hybrid LNBF on a portable dish . . . because you only have to run a single cable back to your RV:
Techwriter, my bad. That is the button I use, just did not look up the screen when I wrote that. Thanks for the correction.
