Bill_Satellite
Oct 31, 2013Explorer II
I think you are getting some confusing information. If you look to the back of your receiver you should have both an HDMI output plus at least a red/white/yellow RCA type connection. If you want to view programming in HD you must locate a separate DirecTV receiver at each TV. If you only need HD at the TV where your one receiver is located you can buy an RF Modulator which will converter the RCA red/white/yellow connections to a coax output which you can feed into the video control center. All TV's will see the one channels selected on that receiver and all other TV's will see programming in SD and not HD.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 23, 2026
