donn0128
Oct 26, 2014Explorer II
owheaton wrote:
I'm hoping someone on here can help me. i just purchased a new Landmark Newport that has three TVs(all HD capable). i had the dealer install a Winegard 4000T in motion satellite and supplied him with a new Directv receiver. he is telling me there is no way to get directive programming to all three TV sets, even if its the same programming. I also then find out that there is no HD capability with Directv..can someone confirm this is accurate?There is no dome that can acquire direct HD. For that you need a trav'ler
my unit is parked in an RV park which has cable supplied to my lot. based upon what I'm being told , I'm having to be ok with standard programming on my main living room 42" TV which has a terrible picture. i hooked up the cable form the park to my unit thinking i could at least get these channels to the other two TVs but for some reason when i auto search for channels, it only shows up 2-3 channels and then for some reason they seem to disappear overnight .
so here's my questions. is there anyway to get HD programing with Directv and my in motion winegard satellite? and is only standard is available, is there any way to pipe it over to the other two TVs in my rig..my receiver only has hdmi output and my rig is wired with coax?
Any suggestions would be greatly appreciated. I'm a sports fanatic and not having access to HD is killing me!!!
Look forward to hearing from anyone who has experience with this type of setup! Thank you
Owen
Like I said NO!
To get HD programing you need either a dish mounted on a tripod or a Trav'ler automatic roof top dish.
To get a signal for the other two TV's you need to wire a splitter and coax from the receivers output or use a Directv genie and two clients.
I think you seriously got the wrong antenna to start with. Then you apparently got the wrong receiver to begin with. Time to go back to square one and totally start over. Get the right antenna then get the right receiver for what you want to do
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
