Bill_Satellite
Oct 26, 2014Explorer II
owheaton wrote:
I'm hoping someone on here can help me. i just purchased a new Landmark Newport that has three TVs(all HD capable). i had the dealer install a Winegard 4000T in motion satellite and supplied him with a new Directv receiver. he is telling me there is no way to get directive programming to all three TV sets, even if its the same programming. I also then find out that there is no HD capability with Directv..can someone confirm this is accurate?
my unit is parked in an RV park which has cable supplied to my lot. based upon what I'm being told , I'm having to be ok with standard programming on my main living room 42" TV which has a terrible picture. i hooked up the cable form the park to my unit thinking i could at least get these channels to the other two TVs but for some reason when i auto search for channels, it only shows up 2-3 channels and then for some reason they seem to disappear overnight .
so here's my questions. is there anyway to get HD programing with Directv and my in motion winegard satellite? and is only standard is available, is there any way to pipe it over to the other two TVs in my rig..my receiver only has hdmi output and my rig is wired with coax?
Any suggestions would be greatly appreciated. I'm a sports fanatic and not having access to HD is killing me!!!
Look forward to hearing from anyone who has experience with this type of setup! Thank you
Owen
1) No dome can receive DirecTV HD programming. Have them remove the dome and install a Winegard Trav'ler. Problem 1 resolved.
2) All of your TV's will be able to receive whatever programming is available via the campgrounds cable connection but you must turn off the power supply to the OTA TV antenna to receive the cable programming AND you must reset each TV to the appropriate Cable setting and not Antenna. If the campgrounds cable signal is terrible (or still analog) your TV picture will be terrible as well.
3) Dish (Network) HD programming is available using your dome antenna but there is no addition or modification that will allow the reception of DirecTV HD.
4) DirecTV SD is pretty dang good and all of the programming comes from only one satellite instead of the 3 required to receive all of the Dish programming.
I am sure I missed answering a question so just ask me (us) again.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
