Dutch_12078's avatar
Dutch_12078
Explorer III
Jun 08, 2016
New cell phone booster review
I have no financial interest in this product other than as a satisfied purchaser...
I recently upgraded from a WeBoost Drive 4G-M cell signal amplifier/repeater to a Maximum Signal MaxAmp RV mobile cell signal amplifier/repeater, and have been very pleased with the results so far. We've now been through a number of areas where we've previously had no signal or a very unreliable signal for both voice and data even using an external antenna, and have had no loss of signal and good data speeds with the MaxAmp. The WeBoost did serve us well last winter in some pretty poor signal areas, but the inside antenna limitation that requires your device to be within a few feet of the antenna was a real drawback with multiple devices in use and two people trying to use them at the same time. The MaxAmp is giving us a good signal throughout our coach and even extends it out to our patio area under the awning. I can't post meaningful speed comparison numbers, although we have checked from time to time, because most of the time when we switched the MaxAmp off in those areas, we would get either no signal, or 1X or 3G data only, compared to a 4G signal with it on. We did learn early on that "bars" on the phone or MiFi display are relatively meaningless, with the signal quality and data speeds being the better units of measure, just as the engineers told us to expect. In every no or low signal area where we've checked, our RSSI numbers and data speeds have been well within acceptable levels using the MaxAmp, and pretty much unchanged in moderate to strong signal areas, as required under the current FCC booster rules.
If you're in the market for a quality cell booster that does what it says it does, I recommend giving the new MaxAmp some serious consideration.
    That's quite a feat.. turning 1x into 4g. I've turned it into 3g with the WeBoost and a 6" exterior antenna, but never 4.
    The biggest drawback to the WeBoost is heat. That thing'll boil water.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 11, 2025
