- Old-BiscuitExplorer III
Bumpyroad wrote:
skyquest4494 wrote:
Hi
For anyone interested this new Rayzar antenna was just reviewed and tested against an old Batwing antenna.
Review is Here
I guess the take home message is "save your money"?
bumpy
After reading review that was the message I got.
Course at $349 I didn't need to read review t make up my mind.
Whatever I get OTA FREE is what I watch. - rvtenExplorerDo not watch enough OTA to justify $399.0.
- joebedfordNomad III have sitting in a box right beside my PC a brand new Sensar IV to replace the so-called omni my rig came with. I think they should have called it a "nomni" meaning it gets no channels.
- MNtundraRetNavigatorThe method of testing by the magazine was rather simplistic. Using the TV's strength meter to get the antenna directly aimed at the tower will always find more stations than their method of picking 4 directions at right angles. The Winegard III, or IV, will find many more then they found. One question I have is how in the h( )l do they know what direction the new antenna was aimed in the first place. The position inside is the last direction aimed at the previous use.
The antenna should have been placed in a level position since it contains a rotating antenna inside the cover. The author should have known the power for the unit comes from the coaxial cable.
Their main market is for the clueless who may replace a omnidirectional directional antenna with something as simple as it can get to pick up some stations, if not the maximum possible.
As for the unit sitting low on the roof the other comments are correct. - Tom_M1ExplorerQuote from review:
"The Rayzar had slightly better picture quality but not enough to be significant. We had to look really closely to see the difference."
The type of antenna will make absolutely no difference in picture quality. There most likely will be a difference in signal levels but if the signal is high enough the TV will perform the same.
The article also shows that the Batwing pulled in more stations even without the addition of the Wingman. - Pirate1ExplorerWhenever the antenna is called an "HD" antenna, I begin to think the article or person making the comment is clueless.
- 1775ExplorerI have yet to find an omnidirectional television antenna that will pull in as many channels as my crank up and turn Winegard. No matter how omnidirectional they claim to be they still have to be turned in another direction to get some channels. This is just Winegard jumping on the omnidirectional bandwagon. When I see a side by side comparison in use I will believe one of these is better.
Whenever I see a comment like this I see an even more clueless person making a useless reply. :R
The wave band is made up of all signals from the infinitely small to the infinitely large. It covers areas we may never identify for years to come.
The television bands we use over certain segments of wavelengths has changed. There are less segments of bands used for digital television transmission. Radios by the way, cover much larger areas above and below television frequencies.
That's why antennas, like mouse traps, come in many shapes and sizes. There is nothing wrong with a manufacturer claiming an antenna is made for the current televisions being produced for the current frequencies allowed by the FCC.
It's time for some of you out there to "Get a life" and to only give helpful replies. - Pirate1Explorer
MNtundraRet wrote:
It is an antenna. It will pick up whatever it is designed to pick up. My batwing could be used to receive FM audio, should I call it HD FM? Calling it an HD Antenna only serves to confuse an already confused audience. I will give any reply I want, if you don't like it, don't respond to it. Sorry that you feel you are one of those I mentioned. If you need some help figuring out antennas, let me know.Pirate wrote:
It's time for some of you out there to "Get a life" and to only give helpful replies. - az99ExplorerThey had to come out with something new to try to empty your wallet.
Put RV and HD in the advertising and it will sell at any price. :)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
