lryrob9301
Oct 09, 2014Explorer
Three things to check:
1) Does your antenna lead run along the same wire bundle as your chassis signal lights. If so, remove the antenna from this wiring bundle and insulate it as much as possible.
2) Pull the radio head and attach a separate ground wire that is connected directly to a known good chassis ground.
3) Check signal light ground wires for good contact and possibly install additional ground wires at each signal light.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: Apr 30, 2026
