laplatarosa
Sep 22, 2017Explorer
Over-the-air digital TV reception?
We are heading to AZ. for our winter stay. Our site is under a steel cover. We want to pull the Class A MH in front ways, instead of backing in. This puts our bat-wing style TV antenna way under the cover. No (very limited) over-the-air reception.
If I added an external antenna, how would I get the signal booster on the existing antenna to improve the signal strength?
Can I run a coax cable from the external antenna (mounted to the steel cover) to the MH cable-in? How do I boost the signal strength?
I have a switch in the MH that says On - antenna - Off - Park Cable. There is a coax connector on that switch. What is this for?
All ideas and help are appreciated.
Thanks,
laplatarosa
Thanks,
laplatarosa
