strollin
May 31, 2015Explorer
Paper maps vs GPS
I read people stating constantly in these forums that they don't trust GPS and want to always verify with a paper map.
Can those of you that believe that's true, please explain why you feel a paper map will be any more accurate than a GPS?
I don't know how maps are made exactly but I believe that the map data comes from the same source whether for a paper map or GPS. It seems to me that the process of producing a paper map would be a longer process than putting the map data into a GPS so it follows that the data used to print a map is probably older than the GPS data. Not only that, but often the GPS data can be periodically updated.
Why then should someone trust a paper map more than a GPS?
