Redsky
Apr 15, 2014Explorer
I mounted a marine type antenna bracket that allows for the coax to pass through the bottom so the hole is covered by the bracket. The bracket holds a 18" omnidirectional 4G marine grade antenna and allows the antenna to be lowered so it is parallel to the roof if necessary. Actually I found no difference in 4G signal strength and now leave it at the horizontal position.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
