reubenray
Nov 13, 2014Explorer
If you are getting SD pictures than you must be getting the satellite signal. I am using a H24 in my coach right now. It does not need the B-band converter. Check the satellite type setup again to make sure the correct type of dish is set up right. Also check your TV and satellite resolution settings. It should be set for 720 and up.
Also what type of cable do you have running from the receiver to the TV? It needs to be either HDMI (best) or component cables.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
