Here would have been an easier less expensive approach to all this,........forget the "pro sensor"
1- Hit menu on my new TV
2- click "signal meter" (same as my sat receiver)
3- Start twisting the batwing till I get a good signal
4- Click enter....on and on till all signals entered.
5- watch tv channel of choice
Right, in my dreams !
Remember they used to be that way, him outside twisting the antenna, her inside hollering, whoa !! Too far ! etc etc.
When the govn't force'm to go digital, they should have supplied a signal meter in w/ that converter,.....and free of charge.
SCVJeff wrote:
RJsfishin wrote:
I received the sensor pro today, and what could have been a quick changeout, wasn't. Both are made to fit into a standard electrical box, But most if not all were just recessed into the panel by doing a square 1 1/2" cutout.
The new sensor pro is bigger on the back side, and near impossible to make the cutout big enuff and still leave enuff material for the screws. So I had to modify a standard household electrical box to mount it in, then mount the box over the existing holes. Not hard to do, and doesn't look bad, just a little time consuming is all.
well at least now you can play with it..
