mikestock's avatar
mikestock
Purchase and install Winegard SK SWM3
I think I'm finally about to pull the trigger and order the Winegars Traveler SWM 3 to replace my, about to be defunct, Kingdome.
These questions ar for anyone who had done this job.
How good are the instructions that come with the dish?
Looking at these optional add on items I know I will need the support mounting plate but the question is, do I need the communication cable extension and/or the roller wear plate?
Also, where does the communication cable need to run to? Does it run to a receiver, the PI or somewhere else?
  • It is highly unlikely that you need the Thin Roof Mounting Plate. The Trav'ler base has plenty of area to mount to your roof, assuming you can walk on your roof.
    The instructions are very good.
    The control cable from the Trav'ler is 30' long and can be placed ANYWHERE that 120V power is available. It does not need to be near anything satellite related. The coax cable will need to run from the antenna to the receiver location. If you only have 1 receiver then the logical location for the controller is nearby so you can drill just one hole for the coax and the control cable. You should not need the extension as most installations will be within the 30' range of the existing control cable.
    I do recommend the roller plate but if you have any piece of thin aluminum sheet or anything of about 4" square you can caulk that in the same place instead.
  • As it stands now, l will probably leave the power inserter where it is in my lower outside electercal cabinet and use existing coax to access this point from the dish. That is where my spliter is located.
    The next question is: does the controller have to be near or attached to one of my receivers in order for the controller to send or receive feedback while the dish is searching?
  • The comm cable is run between the dish base and where ever you put the control box. Which is usually placed near your main TV. Most installers will run it next to the coax cable from the dish to the power supply.
    BTW, before you buy one ask how and where you will get service when they fail. I have been thru two of these things, and would spend 500 dollars more for the RFMogul if I was doing it again.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,798 PostsLatest Activity: May 04, 2025
