BB_TX
Feb 13, 2016Nomad
You must have a coax cable direct from the Tailgater to the satellite receiver (either a vip211k or vip211z). Then for HD you must have an HDMI cable from the receiver to the TV. If you do not need HD, you can use a coax cable from the vip211k or a RCA cable from the vip211z to the TV. Hard to say how your internal coax cables are routed, but the cable from the outside sat coax connection should go direct to the sat receiver without going thru switch circuits. It can use your internal coax cabling as long as it is a direct connection.
Sounds like you may have to pull the TV anyway if you want to connect via HDMI from the receiver to the TV.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,805 PostsLatest Activity: May 15, 2026
