wa8yxm
Jun 21, 2014Explorer III
Where are you... If TV has headpone out and Dash AUX-in and the jacks are about 1/8" in diamater,, Then the cable shown above shoudl be all that is needed.
HOWEVER, you may have to tell tell the radio to use AUX-In, it may be disabled in a menu option or not. You do have to manually select it though.
Set TV volume to mid scale,, This should work. Of course the radio has to be on.
Finally..... You may have noise issues doing it this way, if that happens. go with the FM transmitter.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Apr 10, 2026
