dpgllg's avatar
dpgllg
Question on Television wiring in my 5th wheel
My 5th wheel has a plug on the side wear I attach the cable to for my TV signal. It has three jacks inside the RV one in rear bunk room one in living room and one in our bedroom. We currently have just one TV in the living room.
My questions are:
I use a satellite dish for the Dish network and can never get the wiring to work for it I have to run the cable through the window and into the dish box to get it to work.
What if anything am I doing wrong?
How can I get this to work if I put in a second TV in our bedroom? Do I need another Dish box?
Now if the campground has cable I hook up from campground post to the side of my RV and I can get a signal inside the RV.
Under this connection would the 2nd TV in our bedroom work without any issues?
Thanks for your help
Dave
  • cpaulsen wrote:
    I use a dual tuner receiver and watch 2 different programs on the tv's. One is HD and the other is not.
    One receiver? Boy, Dish must be a whole lot different from Direct.
  • dpgllg wrote:
    My questions are:
    The cable from the outside runs to the inside jack with the power amplified button on it. You have a couple of choices to get this to work both of them will require modifications to how that jack is wired. Jayco's have an A/B plate which you can add as well. If you're interested in doing this, I can elaborate more but the modification will look something like this:
    If you want to view a separate channel, yes. If you want to view the same channel AND have an RF output on your satellite receiver, the modification I alluded to above can help distribute the signal to the remainder of the RV
    Not sure I understand this question, but using the above idea, you can use cable OR satellite. To use both the satellite must have a separate cable run.
  • dpgllg wrote:
    cpaulsen wrote:
    2oldman wrote:
    dpgllg wrote:
    1.What if anything am I doing wrong?
    2.How can I get this to work if I put in a second TV in our bedroom? Do I need another Dish box?
    3.(cable)Under this connection would the 2nd TV in our bedroom work without any issues?
    1. Sat tv doesn't work with any splitters in the coax between the dish and receiver.
    2. If you want to watch a different channel on TV 2, it'll need a separate box and coax feed
    3. Yes.
    I installed cable in my 5ver. From the Dish to a satellite splitter. One goes to the living room and the other to the bedroom. I use a dual tuner receiver and watch 2 different programs on the tv's. One is HD and the other is not.
    OK so would this setup work for me to be able to watch Dish Network on two TV's and NOT the same channel on both?
    EBAY listing
    Yes.....I can watch tv in both places on different channels. The LV tv gets HD and the bedroom does not.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
