TC_Z's avatar
TC_Z
Questions for RVers with DISH
Hi, we recently bought a Winegard G3 carryout antenna and DISH receiver. It works fine, but takes some fiddling, and patience to get it running. I attribute that to me being new and not knowing what I am doing.
I have read, and reread the instructions several times. After I get set up and everything is connected I turn ON the power inserter. My question: is the receiver supposed to already be ON too? Or I am supposed to turn the receiver ON after the antenna has completed pointing. Or does it matter?
Also, on the receiver TEST SWITCH menu there is an option to ALTERNATE ON/OFF at bottom. It defaults to OFF. Do I ever change to ON? Or always leave OFF. This isn't covered anywhere I can find.
Many thanks, safe travels....
  • I thought those portable satellite dishes were powered up the coax by the receiver, which means they are not even on until the receiver is on......??
  • I use a CarryOut GM1518. I always try to turn it on first but don't necessarily wait for it to finish locking on before turning on the power to the receiver while we're setting up. I don't know if it makes any difference though. Ir still takes several minutes for everything to settle out and get all the guide downloaded before I can watch anything. The dish has enough intelligence to lock on to satellites without being connected to the receiver.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 07, 2026
