Passin_Thru's avatar
Passin_Thru
R value for the coax to my Tailgaiter
Hooked up my tailgaiter to the TT wire run and ran a short coax to the Tailgaiter from the exterior feedthrough. Tried to get it going but wire got very hot. Why is the R value in the house Coax different that the R value for a campground satellite hookup? I am going to buy new coax and run it but seems strange to me.
  • Something does not add up.
    Are you saying the coax got hot to the touch along its length or just at the rv?
    Are you absolutely positive the jack you plugged it into is for satellite versus "park cable" ?
    Some miswiring may be putting voltage across the cable.
    More detail please.
  • My Tailgater came with a 50' RG6 coax. That is what you should use if yours did not come with one. I initially used the existing internal short run of coax in the 5er (RG59) until I could run a new RG6 internally. Worked fine with the short run of RG59.
  • R value?
    What the heck do you mean and no, there is no real difference between RG59 and RG6 unless you run the cables hundreds of feet.
