Redsky
Jul 03, 2014Explorer
If the azimuth is correct all you have to do is rotate the dish to pick up the satellites. I put the DVR so it shows the signal strength and rotate the dish until I get a good signal. If you check the azimuth adjustment on home dishes you will see that it is fairly crude as precise adjustments are not needed to receive a satellite signal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Oct 27, 2025
