countrykids's avatar
countrykids
Recharge rate
We will be boon docking at the same location for several days and I am concerned about maintaining battery.power. We have two group 27 batteries, a 4 KVA on board generator and a 40 amp 3 stage converter. If batteries are dropped to 50%, how long does the generator have to be run to refill the batteries assuming little other power usage?
  • Just run it an hour or two in the morning while you're making coffee or heating something in the microwave. Then again in the evening for a couple more hours before retiring and you should be fine. The 12v batteries you have won't have a very high capacity so try to conserve while the generator isn't running. If you need heat, they should be able to run the furnace overnight.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
