mlts22
Feb 19, 2014Explorer II
Recommended backup software?
I personally use Windows Server 2012 at home, which comes with a very useful tool called wbadmin (both command line and the .msc snap-in) for backups.  However for Windows 7 and newer, it, at best, pretty much generates a complete system image, and restorations are not easy on a client Windows edition (open the .vhd, yank the files out manually.)
To help a relative out, what utility do people use for complete backups to external hard disks? I also use Mozy for documents, but for backups to a drive, I've not had that good luck. Acronis TrueImage quietly failed after a few months and would not start without giving any error messages, even after a reinstall. I caught it when doing a random check. I tried Retrospect, and it also had issues where it would just lock up with the CPU pegged until it was manually killed (taskill /f /im retrospect.exe).
The ideal is a utility where if something happens, I can restore individual files, or if the whole system dies, boot a recovery disk, and restore from the external HDD. The ironic thing is that this is very easy with Windows Server operating systems, but for client editions, it calls for a third party program.
