Vulcan Rider wrote:
dryfly wrote:
I will try a toner refill when the end comes.
Do those containers of new toner powder have any warnings on the label ? If please read them. IIRC the boxes of the new cartridges even have a warning about inhaling the powder.
AND anyone who handles loose toner powder should do a Google (or similar) search for "dangers of toner powder" and READ some of the articles.
If you make a mistake handling this stuff it is something that can't be "undone".
Umm.. toner is nothing more than extremely fine powered plastic.
Pretty much an inert and harmless material when handled properly (IE you don't inhale, ingest or get in your eyes), much like many other common office, household or even garage non food items.
Those labels most likely were the result of some person miss using then attempting to sue the manufacturer.
Messing with toner does require a few precautions.
#1, toner WILL go everywhere you DON'T want it if spilled, blown, vacuumed. So don't handle it over carpets furniture or any other object you care about.
With that said, use some news paper or decent sized plastic bag (garbage bag) to cover your work surface.
#2 Don't wear GOOD clothing, it WILL be very difficult to get out.
#3, were protective vinyl, plastic, or rubber gloves (you DON'T want to get toner on your hands, it will leave black marks that take time to wear off.
#4, Don't handle in front of a fan or outdoors in a breeze..
#5, cleaning up, do not use a standard sweeper if spilled on the floor, it will simply go right though the sweeper and be blown out..
#6, DON'T DRY RUB to clean up spilled toner, rubbing creates heat and toner MELTS with heat.. Makes for some ugly stains..
