LouLawrence
Apr 10, 2023Explorer II
If your automatic antenna is a Winegard the tuners condition will not effect it in any way. I use the Trav'ler with DirecTV and have done the factory reset a couple of times without issue. If the message really bothers you it's likely your best choice. The receivers are intentional setup so you can screw with the programming.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Aug 30, 2026
