Ol_coot's avatar
Ol_coot
Replace Mobley
Question to anyone who were using the Mobley for their mobile wi-fi.
ATT has now restricted access to 2 hours and it shuts off. Which is a real pain. Before last month it would stay on as long as it had power. My question "Is there another provider for a mobile Wi-Fi" ? My other half, as she states, got spoiled having it full time and now they take it away. Is there any mobile system that would provide the same ability to go with us when we can finally travel again?
  • TenOC wrote:
    delwhjr wrote:
    I have not experienced any time limits on my Mobley.
    I use the Mobley without any time limits, but I am not often online for 2 hours at a time.
    While traveling my Mobley is on line 24/7. When not using it for steaming or other internet uses it allows remote connection to my trailer's monitoring devices(cameras and temperature sensors).
  • As I recall, if your Mobley SIM lock code was changed from the default, the update that reverted to the 2-hour limit was blocked from installing. It's been a couple of years though since I had the SIM in the Mobley, so I may not be remembering that correctly. Some advantages to moving the SIM to a more powerful hotspot are the ability to connect external antennas, the newer hotspots can use the newer bands, and the ability to connect more than 5 devices.
  • I started having problems getting Mobley to come on-line. Contacted AT&T support, did a reboot and after that went to the 2 hour limit. Wondering now if I should contact AT&T support again to remove/unlock the time limit.
    And before I forget again, Thanks for all the answers. What you-all have said makes sense even to this old country boy. Thanks....
  • I use my Mobley for my work from home connection. Am on line for 9-10 hours continuously on a daily basis. I also leave my work VPN connection alive and connected 24x7 because my company asks for it to stay connected to push patches etc.. No issues.
    Mike
  • Recently had Mobley problems after 4-5 years no problems. Finally got onto ZTE tech support and he had me do a Reset. So now it works - for about a half hour and then is off. How do i fix this?
    Thanks
    David
    Kerrville, TX
  • I've had a Mobley in my RV for the last couple of years and don't have any problems with 2 hour time limit shutdown. But as I recall that was the default setting in the Mobley after some update that AT&T did a while back. To reset it to no time limit requires you to log into your Mobley as System Administrator and change the time limit to unlimited. The instruction booklet that came with my Mobley tells you how to log in as Admin and do this.
    BTW, my Mobley has been powered up in my RV since my last camping trip and I just checked it - it's still up and running fine.
  • OK Bob, have just updated the time to 2 hours as that was the only option available. There was no unlimited option - unless there is another place to look besides the Power Save
  • There was something about having to get a PUC number (or something) that needed to be entered to unlock the full potential of the Mobley if you were moving it to a router or after the software update. Does anyone have the correct info on that issue?
  • I remember unlocking my Mobley SIM and changing the lock code from default, then moving the SIM to the netgear hotspot router, it's been on pretty much 24/7 ever since then, runs on battery when the inverter and/or generator are offline,
    I bought my netgear 815S in June 2018
    I think Feb 2018 thru Sept 2018 will have the most postings about the Mobley SIM to Netgear , service, sims, etc..
    I can't be sure on the date but I think it was Feb 2017 when I gof my Mobley and started service, possibly even 2016
    Will have too look up my AT&T account for start of service date, when I'm less tired and more awake,
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
