DaveG39's avatar
DaveG39
replacing video control center
My video control center that switches various inputs to to various tv's has broken connector. Unit was from ASA and was passive (no 12v input connector required). They no longer have those units. I ordered Magnadyne VCS-10 video control center and found it needs a 12v input which I can't find conveniently in RV compartment housing the electronics. I looked further and only units I found required 12v connector input. Anyone know if a passive unit is available or have suggestions on providing the 12v input?
  • Thanks all. Instructions that came with unit did not mention use of 12v, just showed the plug in position on the unit. I did some searching on internet and found a more complete instruction sheet that solved problem. 12v NOT needed for normal use but only if you need to provide 12v to over the air antenna. Since my over the air is already powered do not need it at all. Wish companies would send complete instruction with units and not require internet searching. Oh well!
    It needs 12V input for what? The Cable, TV, Satellite, Aux connections should not require 12V as it is either not required or it is provided elsewhere. If it has a DVD modulator then you will need to add 12V power but you did not have it before so you should not need it now.
  • The newer TVs have AV HMDI inputs that you switch your inputs and you will nor need the push button switched
  • You want one with physical switches doing the work, not electronics
  • I changed mine out that failed to the later models that require 12 volts DC. The 12 volts DC on mine replaced the power supply to the over the air antenna. I used the feed to the old antenna power supply to power video switch.
    See note 1 on your installation instructions.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
