NancyG's avatar
NancyG
RG6 Coax
We purchased the Tailgater and would like to make use of our outside connection for Satellite, rather than running coax through a slide and directly into receiver. How can we determine if the connection for satellite on outside of fiver is RG6? It runs from outside the trailer into the entertainment center to an outlet marked Satellite. We have tried this connection but cannot get it to activate. We bought Radio Shack RG6 for use between Satellite In connection and the Receiver.
Update: noted that Radio Shack coax is marked RG6-U and coax in Satellite connection is RG6. Could this be the problem?
  • Whether the coax in the fiver is RG6 or RG59 you should have success and I would not be concerned about what's inside. Now, if you want to try to use a connection labeled Cable to provide a connection to a satellite antenna, this will not work or will not work without some cabling modifications.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
