- kmbeltExplorerI have a 90 degree HDMI one for the exact same reasons. Works flawlessly.
Also, those of you that mentioned MonoPrice.com. Good call. they make great quality cables for way less cost. Buy our network cables at work from them. - RedskyExplorerI bought the cable with one end straight and the other with a 90 degree HDMI connector. Available in different lengths depending upon what you need.
- LittleBillExplorermonoprice here, used in the stick home, but i used both hdmi and coax right angles, worked perfect
they hold fine, i wouldn't see a issue in an rv - johnrbdExplorerIn Oct 2013, I got 2, one 90 and other 270, used with Chromecast. No issues to date.
Purchased from monoprice.com, along with other adapters, 15-ft hdmi cable and 50-ft ethernet cable. All cheap and work perfectly.
On one TV, I attached the cable coming from adapter to TV mounting hole to better secure it. - Executive45Explorer IIII have used the 90 degree adapters for three years with no problems. I bought mine locally at Home Depot....Dennis
- dan-nickieExplorer III use them and got them on Amazon. No problems.
You have to look at them closely.
There is a 90 and 270 degree adapters.
Mine needed the 270 degree. - bob213ExplorerI use the rt. angle adapter on my satellite box that I switch from the house to the TT. So far no problems. It stays connected and helps with the tight squeeze in the cupboard next to the TT television. You can get them at Amazon or here:
hdmi adapters
Monoprice has them as well..... - donn0128Explorer IIBought some coax adapters off amazon a while back. Two broke after that I quit using them
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
