We watch the digital counter real close when we first start scanning. If it doesn't do much in the first 15% of the scan we swill stop the scan and move the antenna one way or the other a few degrees and then start scanning all over again.
You also have to be using the ANTENNA MODE versus the CABLE MODE on the TV scan menu... You also have to scan the digital station at every place you camp at. They all use different channels and ID number etc... The ANTENNA PANEL WALL PLATE unit also has a push-button on it and this needs to be pushed ON. It will turn on a small LED LIGHT when it is working properly sending 12VDC up your RG coax to power up the OTA ANTENNA PRE-AMPLIFIER. When you are connected to the camp groound CABLE this push-button has to be OFF.
The DIGITAL CHANNELS are very narrow beam width and you really have to be pointing right at the BROADCAST transmitting station real good.
There is a small unit called SURELOCK MDL SL1000 by KINGS which will find digital HDTV station before you scan them. YOu might want to get one of these to help out.
It takes some practice to find where the BROADCAST transmitter is located in the local towns... You can get a basic direction on-line and point the BATWING OTA Antenna in that general direction.
Sometimes it is just easier to look around the camp ground and see where the other campers are pointing their OTA antennas.
If you do get one station then while watching it on your HDTV after you have it all scanned in you can move the OTA Antenna back and forth and get the antenna centered on where you get the best view. In the digital world the best view is a perfect picture without any pixelating. Once you have the antenna centered then do a scan again.
We get 6-36 digital high def TV stations just about everywhere we go here on the East side of the US.
Roy Ken
