BB_TX
Jun 09, 2017Nomad
If you only have one coax input then it probably goes thru the switch for selecting between cable and antenna. Not good for sat reception.
You may find a dual coax wall plate somewhere with a short coax jumper between the two. If so, you may be able to remove the jumper and connect a coax cable from your sat receiver to one or the other of the wall plate connectors (one that connects to the outside connector). That worked with mine. I later added a new external coax connector and ran a new cable from there to a new inside coax wall plate to connect to my sat box.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
