enblethen
Jun 09, 2017Nomad
Yes, you should be able to test for 12 volts. Turn on isolator, use volt meter between core and shield. (center of the connector is core, shield is the larger male thread)
Just because you have 12 volts doesn't mean you will get the digital satellite signal.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
