BB_TX
Jun 10, 2017Nomad
IBcarguy wrote:
Btw, a month ago the system worked fine. I don't think anything has changed but it won't work now unless I bypass the trailer wiring. .........
The fact that it used to work with the internal wiring, but doesn't now. And that it does work when wired direct, pretty much indicates something is now wrong with the internal wiring. A loose or bad connection somewhere probably. Even a loose/marginal wiring connection can check ok looking only for continuity or for voltage with no load.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
