mackyb's avatar
mackyb
Sat TV Receiver
I am considering going to sat tv in the home for a couple of reasons. One of those is the ability to take it along when we are camping in remote areas. My question is: Can I bring just the sat receiver from home with recorded shows on it, hook it up to the tv and play recorded programs without having it plugged in to a sat dish?
  • RoyB's avatar
    RoyB
    Explorer II
    It is very easy to bring along a tri-pod type SAT DISH. This is what we dis for a couple of years.
    Our portable DISH setup had two PORTS on it so I brought two SAT RCVRs from the house on our trips. Ran two RG cables from the two SAT DISH ports with one going to the TV CONSOLE and the second one going to the BEDROOM setup. I also brought along two SAT RCVRS form home. Connected the RG cables to the ANT INPUT on each SAT RCVR and then run VIDEO CABLE from the SAT RCVR to the local TV SET VIDEO IN port.
    This allowed us to use each Main and BEDROOM TV sets to tune different channels on the SAT RCVR side.
    This was all condoned by DIRECTV for us to use our SAT RCVRs anywhere away from the home location. The only deal was we would lose our LOCAL TV subscription.
    Our SAT units were old and most always would lose their settings when unplugged from the house 120VAC so we had to call DIRECTV to reset them or go online to do it. Just make sure you have your acct number and SAT RCVR info with you.
    Worked good for us with no extra charges from DIRECTV.
    Easy setup with the portable dish when you got use to the procedure.
    This was back when using standard SAT TV RCVRS... Have no idea how all of this would work with the new stuff they have now...
    Roy Ken
  • I've never tried it that way so don't know if it will work. I'm sensing there may be a problem because when you plug in the sat box it automatically looks for a sat signal. There have been times when I've had an issue with my sat signal and upon plugging the box back in it still couldn't find the signal and would not let me get to the recorded programs in "My Recordings".
    You might want to try it at home by unplugging the box and then disconnecting the antenna. Plug the box back in after 10 minutes and see what happens. Also disconnect the phone line and or internet if you have it connected to the box.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Feb 27, 2026
