Sort By
- 1492ModeratorMoved from Forum Technical Support
- 2oldmanExplorer II
- cekkkExplorerThis will probably be moved, but a search of the subject will open many discussions. Personally I like DISH over Direct. For RVers they have
the fairly new Tailgater satellite that, coupled with the 211 or 211k receiver can have you up and running in minutes. Setting out the Tailgater just means placing it on the ground with a southern exposure, hooking up its coax to it and the 211, five minutes. Turn on the receiver and it finds the satellites and downloads all necessary info in about 15 minutes. If you are more than roughly a hundred miles from your home and want the locals in your new area, a call to DISH will have them hook you up with locals in that new area. You need a physical address to get that done. If not in an RV park give them a nearby store's address. Naturally you need a program package.
