GTO66's avatar
GTO66
Explorer II
Aug 28, 2013
sattelite signals
Is it the clouds or rain or both which cause the loss in sattelite signal? I just switch from cable to directv and can't believe how often it seem to lose the signal.Is that just the way it is or can something be add to improve the signal?
  • I have had DT ever since it came out. I have lost the signal maybe three times and have seen plenty of thick clouds.
  • I have family that dumped their beloved Directv after moving to south FL. Seems I have heard of other complaints about that part of the country. Wonder why?
  • SCVJeff wrote:
    Bill.Satellite wrote:
    Jeff,
    Guess I am really confused now. "Predicted rain fade?" I have no idea how you want them to predict the weather. (That's a joke I know that's not what you meant.) If you are saying that the DirecTV or Dish signal is not as strong in various parts of the Country that kind of info is pretty well documented. It's up to the antenna owner to see what their signal strength numbers are and if they are dropping a call to DirecTV or Dish would be in order. The auto pointing dishes take care of that automatically every time they deploy but a home installation or a manual portable setup can change with time.
    Assuming I am completely off-base, please let me know what you are referring to.
    As I said above, on satellite as well as terrestrial microwave, there as very complex programs that run all the calculations and will tell you what the expected outage is in a given year of any given area, in minutes.. Obviously this doesn't go from storm to storm, but they contain loss averages in any given area in the country and formulas I don't pretend to understand, but they work. The footprints obviously are factored in, but what matters is the intensity of weather in any given area of the country. This has nothing to do with auto-pointing any things. It's all math: transponder power, antenna gain, path loss (and that includes weather), and finally the receive dish, then a report gets spit out.
    If you had those lists, when someone says that their receiver is out 10min/month ( example), you could look at the charts and say, yeah it's possible since the charts predict 120min service loss per yr, and this is awfully close. Or the charts say 4min/yr, in which case you say with confidence that something is clearly broken.
    Ever wonder why satellite or microwave antennas are the size they are? This is exactly what determines all if this. While it all may seem pretty generic in consumer land, there is allot of science that went into the determination of what works (usually) and what doesn't.
    I guess I was not off base and you actually were hoping that I might be able to get someone at Winegard to predict the weather. If you need to know when you might lose signal you could always consult the Farmer's Almanac or just watch the local weather forecast. The solar outages are extremely predictable. Weather? Not so much!
  • I was finally able to get the readings for the 101 satelite.All the readings are 98 to 100 except line 9-16 where the third number is 76. would this cause me to loose the signal? Thanks
  • Bill, you clearly have no idea what I'm talking about to the point of making condescending remarks for your lack of knowledge. Your attitude is the reason that forced you off of other forums, and until now you have pretty well kept it in check..
    How about you call the same people that set you straight several weeks ago when you made incorrect statements on the amplifiers. Again you might learn something.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
