GTO66 wrote:
The lowest number is 77 on the 9-16 line. To me it seems to be getting worse.At first heavy rain would knock it out. Now steady moderate rain does.
The fact that you think the situation is getting worse is indicative of either your alignment being a bit askew or maybe there's a tree in the way that has gotten a bit larger. If there's a tree in the way then when it rains the water on the leaves will be a far greater signal block than are the dry leaves. For example, at the CG where I am currently at my dish is looking through a pine tree and I can get HD signals on most of my channels without an issue. However, this morning it is raining lightly and the HD channels are impossible to receive, but the SD is still coming in OK.
