az99's avatar
az99
SD Card Unreadable
A friend had a problem with the SD card in their Nikon camera. It has 100+ photos from their once in a lifetime vacation. Nothing out of the ordinary was done with the camera.
I have tried to read it and use Zero Assumption, Recuva and other programs with no luck. It seems like the card is not even being recognized or read by the computer. I also did the Check Drive function on Win7 and that also shows nothing there.
I used a SD card I had and even quick formatted it and Zero was still able to recover all files. This one does nothing.
I thought I would run it by the tech geniuses on here and ask for suggestions.
Thanx
  • az99 wrote:
    The card is not readable in any camera or computer at this point.
    The card was purchased new with the camera about 2 months ago.
    If it's new, you should be pursuing a warranty remedy.
  • The computer recognizes it when inserted but will not allow it to be viewed like the files are corrupted or something.
  • The card is not readable in any camera or computer at this point.
  • Sea'scape wrote:
    Does there camera still read the card and can they review the pictures on the card in their camera? If not, card is probably toast. If they can,try connecting the camera to the computer using a cable and see if they can be downloaded that way.
    X2 on the cable. I had to start using that awhile ago when my card would no longer read in the laptop.
  • As long as the SD card is not too old, they do have a finite lifespan, it could be that it's not making proper contact with the reader. Make sure the metal contacts are clean. Also, sometimes these cards get slightly warped. Try placing a strip of an envelope or similar on the opposite side of the card when inserting into the reader. This may force the contacts down on the reader.
  • Does there camera still read the card and can they review the pictures on the card in their camera? If not, card is probably toast. If they can,try connecting the camera to the computer using a cable and see if they can be downloaded that way.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 27, 2025
