4X4Dodger's avatar
4X4Dodger
Explorer II
Dec 01, 2015
Second Bad Gas Hose from CW
After buying my weber Q at the Flagstaff AZ. store on Sept 27 2015 I returned the next day to get a gas hose to connect it to my small Propane tank. (I was not happy that NO WHERE on the Weber box did it indicate that you had to use those small camping canisters. Which caused me to make this additional trip to the CW store)
I used this hose about three times before it died. I had to replace it in Phoenix on October 3rd.
To make sure it was the hose and not the Weber or the tank, I first connected one of the Coleman canisters to my Weber...it worked. Thus the regulator was ok.
My propane tank was full and would run my generator with a different hose, So it was not the tank.
I connected the hose to the tank, turned on the valve and used a matchstick to depress the valve stem in the hose connector. Gas should have released. It did not. Meaning the Hose was bad.
CW Flagstaff replaced it. Gave me another.
Same problem with this hose. after about 5 uses it stopped working. Unfortunately I am now in Baja Mexico and replacing it is difficult if not impossible. And Now I am forced to use the MUCH MORE EXPENSIVE Coleman canisters for fuel for the BBQ. These are expensive here and hard to find.
I will be expecting MY MONEY back this Spring when I exit the BAJA. I will NOT accept another of those cheaply made hoses from CW as replacement.
CW needs to review this issue I am certain I did not get the only two defective hoses.
I have spent a few dollars at CW including a generator this year. I am NOT happy.
I would like a definitive statement from GSE by email that I can return this hose in late March or early April of 2016 when I return to the states from Baja.
I will await your (hopefully) quick reply.
Regards
  • Hello 4X4Dodger,
    My apologies this happened. I have your contact information and will send your request over. Thank you.
    Elizabeth
    Marcus Rapid Response Team
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Jan 05, 2026
