SoundGuy
May 22, 2018Explorer
wildtoad wrote:
There is no better RV antenna than the Winegard Batwing, with the optional Wingman attachment. Add also the Sensar Pro power supply/booster and you have a good setup. There are also apps for smart phones that will help you find the closest towers for aiming purposes.
If you go with the Yagi/bowtie you may still need a signal booster, and a way to turn the antenna to get what reception there is.
I'm sure the OP already knows this, also knows that even with a Sensar IV head and SensarPro driving it that reception is often still marginal to none at all ... just as I also know this. The OP's solution is correct - a better (home use) head mounted much higher up above the roof. I would think this might be the one exception for mounting a 2" bumper receiver, even a bolt on, as that would allow then mounting a flagpole holder like this to the trailer. To rotate the head I'd just keep it simple by manually rotating the pole to which the head is mounted. I just haven't bothered myself because I really don't care all that much about watching TV while camping, 'though my wife would probably think this was a worthwhile mod. ;)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
