wa8yxm
May 22, 2018Explorer III
I have a Sunsetter Telescoping Flag pole.. I will link (I hope) to an even better one (if I still have the link) (did not but have working Organic Computer (brain) and it remembered ENOUGH of the URL for Google to find it)
The mast I have has a "Park on" base (DG's sells one that way too) but the base broke so I now have a stake down base (Keeps the bottom from slipping)
And about six feet up on the side of the RV is a common mending Bar, a flat metal bar with 4 screw holes. lag bolted with some washers between teh bar and the body so as to have a gap.. Painted to match the RV it's hard to find.
I use a cargo strap to secure the mast at that point. Does not wander too much
This holds one end of my Ham antenna and my Wi-Fi client.
Never put a TV antann on it.
The DG's model has special locks so it is designed specifically for directional antennas just so you know.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
