Huggybear49's avatar
Huggybear49
shaw satellite
we have a shaw receiver using the auto dish on mh with quad lnb gets 2 sats. been losing hd signal in rgvstx get refresh lasts a few days only.talked with wineguard they say shaw shutting down the system we have in early 2018 any comments
  • A few years ago in Quartzsite I was having a similar problem on a older style Shaw HDPVR with the large dish mounted on a tripod. I was having it refreshed constantly until it wouldn't refresh anymore. Spent lots of time with Shaw on the phone trying to get it to work with no real success. Replaced with a new receiver and the new lnb and my problems went away.
  • Right, thanks for that. Seems like the OP might have been just a bit more transparent about his location for the most helpful responses.
  • A guy moved into our park a few sites down and said he needed help with his Shaw Direct install. I've done it many times so I said I'd do it. Well, I don't know what the problem is but I wasn't able to find any signal. RG6 cable directly from the LNB to the receiver. All angles were correct. No obstructions. Frustrating!
  • Did the guy have his Shaw working before he got down to Mesa? Maybe he got a new receiver but still has the old LNB's?
  • I got it working.
    I brought his rx over to my dish and hooked it up. Seemed fine so they did a refresh. Was working on my dish within 15 minutes. Both dishes xKu LNBs.
    So I took it back to his dish and had a closer look at the angles. I knew the elevation was off by one degree but figured that wasn't enough to make zero signal. Then I realized that he had the azimuth bolts so loose that the dish was leaning forward on the tripod - maybe 2-3 degrees. So add that to the 1 degree on the gauge and it was enough to miss on elevation. Got him up to 93%. Mine gets 96% but his is a 60 and mine is a 75 so that makes sense.
    I just hate being defeated by technology. Not today...
  • thanks for the feedback have all channels back now even hd go figure keeping it hush hush lol
    The two original satellites do carry HD so you can get them down south. The newer third satellite is all HD and can't be seen far south. Eventually as the older ones die all stations will be transferred to the newer one.
    Just noticed your page re hooking up the Shaw Direct dish, here is a link that others can use to set the dish up on a House or Tripod.
    http://www.kusat.com/Shaw-Direct/System-Installation/
    And the Dish Pointer site, use ANIK F1 and ANIK F2
    http://www.dishpointer.com/
    Just put in your location and choose your Satellite. You can zoom in to your location and move the Green Spot to your Dish Location.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
