bob_nestor
May 24, 2023Explorer III
wa8yxm wrote:
Get a new router I had that kind of router(One SSID two bands) and several devices refused to connect to it
My New TP-Link Archer-10 has 3 SSIDs two are the same ..almost.. I set them to the 2.4 GHz SSID to the same as the old router (Saves logging in all the old hardware) likewise the PSK I set the same.. The 5 GHZ band is the same save for the addition of 5GHz to the ssid..making both of the bands Unique The Third SSID (Guest)is optional.
Now my printer works over Wi-Fi. Smart plugs and devices work.. and Raspberry Pi's are very very solid.
Some routers like the Archer use unique names for 2.4 and 5 gHz and distinguish between them by appending a "_5g" to the SSIDs. Others, like some of the ASUS routers, can use a single name for both and when a device tries to connect it automatically selects the correct WiFi. ASUS calls this feature "Smart Connect" and it can be enabled or disabled via the web interface to the router. However, there are some devices which have difficulty connecting if this is enabled in the router. I have both an Archer and an ASUS along with various tablets, phones and such. At least one of my Android tablets can't deal with the auto-select.
The other issue with connection to WiFi has to do with hidden SSIDs. Most devices let you manually enter the SSID and password to connect to an SSID that is hidden or not advertised. Some devices can't do that like a couple of the inexpensive Android tablets I have. At least one of the Androids I have also has an issue trying to reconnect to a previously known (and saved) SSID if that SSID is later hidden which isn't a problem for better engineered devices.
As for hiding SSIDs, some feel it offers some additional level of security, others claim this isn't true. Hiding the SSID at least keeps people who aren't all that tech savy from seeing and trying to connect to your WiFi though.
In short, if the tablet is an inexpensive (cheap) one, it may have a number of small nagging issues trying to connect to, use and reconnect to WiFi. But as others have stated, if the tablet doesn't support 5ghz, it won't see when it's available and therefore can't/won't use it.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
