- lolapaluuzaExplorerI usually buy a tuner online on the website https://www.mrdepot.ca/products/brother-hl-2240-toner since it is much cheaper in terms of money and I do not have to go to the mall to buy a new cartridge. It seems to me that the toner consumption is much less in this way. But perhaps this is speculation.
- ferretgrandpaExplorerI second the Brother.
Carryed a Brother monchrome laser for several years. I don't need the scanner, but do demand Duplexing. I've had several that passed 50,000 impressions. Fitted in a storage cabinet over the TV.
Brother Toner cartridges are also very easy to refill (saves alot, like spending $10 to refill a $70 new cart)
Tom - GdetrailerExplorer III
folivier wrote:
We keep an HP M15W laser printer in our coach, very small but it is a printer only. Scan and copy works surprisingly well using your phone to take a picture then send it wirelessly to the printer.
Correct, that is why I recommended the HP M29W which is the "twin" to the M15W in size other than the extra bit of added size for the built in scanner on top..
Phones do take a decent pix but they have a lot of limitations like getting the phone camera lined up straight and true enough to not skew/angle the picture of the paper you are taking.. Not to mention holding the phone still enough to not blur or move away from the paper.. Getting even lighting across the entire paper can be a challenge and often phone cameras like dedicated cameras will have shadows across the photo without proper lighting.
A scanner since it has it's own light source will properly light the entire document evenly and the paper will lay flat and even.
Scanners do have their place and a phone camera sometimes just can't do as good of a job of a scanner.
I own them all, a bed scanner, a phone with a pretty good camera and a handful of standalone cameras up to 15 MP and yet always get the best scan in digital copy via the bed scanner and it is very quick. All without the need to position, re-position, hold breath take a bunch of photos and chose the least blurry.
So when quality of the digital copy of a piece of paper or even a photo print it is hard to beat the ease, speed and quality of a dedicated document scanner. - sandybill9ExplorerTake a look at the Brother MFC-L2710DW. $199.99. I have this at home, super usefull. https://www.brother-usa.com/products/mfcl2710dw#
- folivierExplorerWe keep an HP M15W laser printer in our coach, very small but it is a printer only. Scan and copy works surprisingly well using your phone to take a picture then send it wirelessly to the printer.
- jcpainterExplorer
ktmrfs wrote:
If size is important I'd look at a ink jet. you'll likely find many more choices.
Even then small size = $$$$$
Yes, but we want to keep this in the RV and so often the ink jet cartridges dry out when not used for a while. - jcpainterExplorer
bob213 wrote:
I have the HP LaserJet Pro M29W that Gdetrailer referenced above and am very happy with it. Great output, low cost consumables and it does scan in color but only prints in Black.
Thank you so much for the review. I appreciate it and will probably order this one. - ktmrfsExplorer IIIIf size is important I'd look at a ink jet. you'll likely find many more choices.
Even then small size = $$$$$ - bob213ExplorerI have the HP LaserJet Pro M29W that Gdetrailer referenced above and am very happy with it. Great output, low cost consumables and it does scan in color but only prints in Black.
- Taxman2436ExplorerNot a laser and Pricey but if you’re going to use it on the road as much as I do it’s worth the price:
https://www.amazon.com/HP-OfficeJet-250-Portable-Wireless/dp/B01HGD8R5S/ref=sr_1_2?dchild=1&keywords=hp+mobile+printer+250+all+in+one&qid=1616198948&sr=8-2
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
