gutfelt
Oct 16, 2017Explorer
myredracer wrote:gutfelt wrote:
IF you would read posts of suggestions others have posted you would clearly see that you a NEED DUAL LNB if u want to get two satellites at the same time!!!! one LNB is only good if you have a automatic dish that changes sats when your receiver gives it a signal to do so.
Where did I say I am trying to do is get two satellites with one LNB? I am aware you need two LNBs for that. Perhaps you need to go back and read what I've posted. I only want to get 82, or perhaps I didn't make that clear enough. The problem I am having and trying to understand is why the the Birdog meter is telling me I'm locked onto both 82 & 91 no matter which one I'm pointed at and with only one LNB. I now know that I couldn't get 82 at the last CG due to trees but the meter was telling me I was locked onto both. I appear to have either a problem with the meter or the type of LNB I am using.
I'll watch 91 if that's all that I can get, but nothing much worth watching on it for us and the only benefit would be that it has the program schedule beyond one hour out while 82 only shows one hour out
all I read was you said (asked)
Questions are:
1. Can a dish with only one LNB receive two sat. signals?
and I said no you need two LNB unless the dish switches automatically
between satellites or as u know move it manually
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
