myredracer
Oct 22, 2017Explorer II
Bill.Satellite wrote:It'd be an experiment of sorts to see far I can go. We're mostly in WA or OR anyway tho.
If you are planning to travel much farther South and still receive the Bell programming it really won't matter as the signal simply does not exist. If you stay in OR and WA you should be fine.
I just got another Birdog meter. It's an older model and got it for cheap just to get the case (seller sold it for parts as they didn't test it). Works perfectly. It does exactly the same thing though. If I'm aimed at either 82 or 91, it says it's locked on both. Have tried both the Invacom LNB and our other dish that has a standard LNB and same thing.
So it's something to do with the meter. Have contacted the manufacturer and will see what they say. May also talk to a local satellite system installer.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,806 PostsLatest Activity: Jul 22, 2026
